dji go 4 focus issue on android
Cláudio
Hi, I need help if possible.
I finish a tabet nvidea shield k1 android in my mavic pro with the dji go 4 version 4.02.
I noticed that I do not have auto focus function (AF-C), can anyone help me.
I have seen several videos on youtube where this function is active, or it will only be in the ios system.
Thank you
So far as I can see with Android it focuses each time when you start a recording - but not if you take a still.
This can have bad consequences if you start recording on the ground and forget to tap on distant contrast line once higher,- but I don't like the idea of it focusing during recording on it's own as you see the shunt in and out.
in this two img u can see the difference i same app just diferent android and ios, and on ios u see AF-C active. that is my questios (issue)
The "Enable AFC Mode" setting is currently only available in the iOS version of DJI GO 4.
This setting is now also available in the current version of DJI GO 4 for Android.
Bdog5108
