D
Windows is giving you that error, not the Goggles. They tend to not correctly unmount the Disk when powered down. Just either let it run, or ignore it.Just to clarify... This is the MicroSD card that is in the DJI goggles. When I delete the two files off the card, and reinstall the micro SD card. The goggles rewrite the 2 files to the card and then the goggles throw this error. The goggles connect and work fine. This happens on two different sets of goggles and on Windows 7 and 10. If you remove the MicroSD card from the goggles this does not happen on either system. I have tried 2 different micro SD cards with same results. Very weird
