DJI GOGGLES NANUK 918 CASE BEST USAGE.
Skymax
How to remove DJI Goggles from the NANUK 918 CASE without damaging the Goggles/Headband connection.
And a few words about the Case itself.
(I mistakenly spoke, "CH Case" in the audio but it is indeed a NANUK 918.)
I liked your video...
What's to keep you from simply taking a sharp blade and removing a few mm of cushion on the part that holds the goggles. Make it a little less "tight."
The additional space will facilitate removal and have no effect on the ultimate effective protection.
I've done that on my Phantom 4 case. Way to tight, hard to get the Phantom out. A little cutting and a perfect fit.
Reactions: Skymax
Thank you i didnt realise the Vid was so long until I finished it, I prolly should have made a separate case review.
Yes you're solution is also valid and would solve the tightness instantly.
ErieSkyPixel
