For the FlyApp you have to go to the DJI Downloads webpage to get it. Best to have a wi-fi connection as well for both the FlyApp and firmware for drone.
Updating the firmware is as stated - thru the FlyApp in the Settings Section (3 dots in upper right corner of screen) if the drone is connected - which is required to update. If you have more than one battery, you will also have to put in each battery to do the update as well.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
