DJI Mini (1) batteries charging slow
Wildcatgary
Pima County Arizona
I fly a battery for 20 minutes. Then I takes 3+ hour to charge?
(I have 3 batteries)
seems slow..... anyone else see this?
Can I use the Mini 2 battery charger w mini (1) batteries ?
Yes you can. If you use a proper charger (QC3) it'll charge in less than an hour.
Mine is the same , three batteries in the charger that came with it ( fly more pack ) and original cable/adapter . Still takes hours to charge the batteries ,even one alone is a couple of hours . Not an age of batteries issue as they have always required that amount of time .
If you haven't as yet, make sure to UPDATE the battery firmware.
Recently bought the one shown in the attached picture. Batteries charge in just over an hour. Way faster than the charging hub.
The price shown is in Canadian dollars.
Reactions: Capt KO
USB charging cables are not all the same. Must be capable of 2amps or better. The original works fine but if using another, might want to switch. If your lights are way slow, try a different one or two. I use a usb amp meter to check.
Reactions: EyesWideShut
NIKLM
