DJI Mini 4 "Aircraft Storage Full" (Code1C001COA) - clearing via Mac not fixing it
jorgie2u
Australia
Summary​
When powering the DJI RC 2 and pairing it with Mini 4 Pro, the following message appears:
“Aircraft Storage Full Backup File and clear space (Code: 1C001COA)”
Background Info​
When I tap Profile + Settings + Storage, the RC Internal Storage shows 4.5GB/21.6GB (after cleaning all Caches (no SD Card installed in RC; therefore, SD Card location not selectable)
After tapping “Go Fly” + “Camera” + “Storage”;
  • “SD Card” shows:
    • 465.9GB/477.3 GB available
  • “Internal Storage” shows:
    • 5.0MB/2.0GB is available, followed by the “Aircraft internal storage full " popup. Storage location switched to SD Card.” I then tapped “OK” to close the popup.
Attempted Fix​
Following the advice provided in another forum, I connected the Mini 4 Pro to the Mac via USB and deleted all unneeded files, achieving the following:
  • Mini 4 SD_Card info shows:
    • Capacity: 512.7 GB;
    • Available: 500.4 GB
  • Mini 4 InternalSto info shows:
    • Capacity: 2.28 GB;
    • Available: 158.6 MB
      • Note: Using Mac's Finder, this InternalSto location shows two folders
        • DCIM (Size: Zero bytes (Zero bytes on disk) for 2 items
        • MISC (Size: 40,960 bytes (131 KB on disk) for 5 items
Could someone please clarify​
  • How can I stop the message “Aircraft Storage Full Backup File and clear space (Code: 1C001COA)” from appearing?
  • Why does the Mini’s InternalSto show that only 158.6 MB remain when Mac’s Finder states that only 131 KB are stored within the MISC folder?
  • How can I safely increase the Mini’s available InternalSto to prevent the “Storage Full” warnings hopefully?
Note: Using Samsung EVO Plus 512GB V30 U3 A2 used on Mini 4 (recommended list)
Reactions: bassnbeau
You can't increase the internal storage, it is fixed. If you don't see anything via the USB connection, something might have gone wrong in freeing up the storage at some point. That should be solved by formatting the internal storage (through the RC2). Given that you have nothing stored on it, it is safe to format - you will not format the drone ;-)
Summary​
Background Info​
  • “SD Card” shows:
Attempted Fix​
Follow Frank's advice and reformat the internal storage. It's likely there's a damaged file in there that's compromising the file allocation table reporting incorrect storage space.
Summary​
Background Info​
  • “SD Card” shows:
Attempted Fix​
If you work through the main screen of the FLY app (account/settings) you have the option to delete all cached files. Try this. You'd be surprised as to the volume that builds up without your knowledge. Also clear the video cache at the same time.
Probably because you put the contents in the trash but then didn't empty the trash with the aircraft connected, so the fiels are in a hidden trash folder but not actually deleted yet.
Do so, or you can also just format internal storage from the camera settings.
rom10cort
