DJI Spark going at 100 km/h?????!!!!!
Cool! What i'm lacking is the router thing. If I had that, then I would probably fly more.
Using any wifi range extender is essential for this drone. It amplifies the signal which is the only channel for communication. Video and radio. If you place it correctly, you can have almost the range of the Spark (CE) and also indoors, you can fly thru rooms. A very cheap, but effective solution to upgrade the drone.
Reactions: Daniel NZDF
Ok, cool. Can you maybe recommend one to me? Thanks!
And please repeat this flight and record it with something. I wanna see the old hardware zipping aroung with 100 kmh
I ended up buying a mavic mini instead a few months later, man I was very disappointed.
Eh you got something better :D
Still have a Spark but to me it was kind of the least exciting thing DJI released. Size was kinda revolutionary but at too much cost to performance.
Took 8 years but the Neo 2 is basically what the Spark was meant to be IMO.
My brother doesn't own any other drone except for a spark, so it can't possibly be from another drone.
It can if you or he are BS'ing us.
Not making that accusation, just pointing out that the information you've provided is just about impossible. As mentioned, the motors aren't powerful enough, nor can the battery system deliver the power/current necessary. These are simply hard facts.
If you went on a SmartCar forum and claimed you'd taken the vehicle 130mph in the Bonneville Salt Flats, no one would believe you, no matter what "data" you provided. With good reason.
Not making that accusation, just pointing out that the information you've provided is just about impossible. As mentioned, the motors are powerful enough, nor can the battery system deliver the power/current necessary. These are simply hard facts.
Sure will! This Sunday I'm doing another flight.
Maybe it was a GPS glitch. Doing another flight soon to see what happens. At any rate, it was going above 50 km/h. It was going much faster than it usually did. Remember also that it was basically uncontrollable while it flew, and lost power and went into a dive.
Other puzzling aspects of this story: It's been claimed it was "vertical"... I assume that means it's was pitched forward 90 degrees? If so, it was producing no lift, and would drop like a rock from gravity. As others have noted, a pitch angle like this would shut the drone off.
Maybe it wasn't quite at 90 degrees, but it was "vertical" to some effect. Remember in drone racing, the fpv drones go almost vertical, and the don't fall out of the sky. However, I see your point that the IMU would stop the motors at that angle. Also remember that whatever speed it went at, in lost power and basically almost fell out of the sky at the end of the speed run. Ie, battery couldn't support the flight, and it became very difficult to control. That doesn't normally happen at 50km/h.
Maybe you guys are right, and I'm wrong🤣 I didn't want to start a forum argument with this thread. We'll just leave it at that.;)
show us what you can after your flight on sunday.
Cheers mate
You're mistaken in this. Typical pitch in drone racing is around 45-55 deg. A near full pitch forward, say 80 deg, does not leave enough vertical thrust ("lift" in classic flight dynamics lingo) to control the height of the drone, which is critically important to making it through gates, making tight turns, etc.
I'd recommend reviewing the classic 4-forces balance of flight (thrust, lift, drag, gravity) and how they interplay.
My brother is now not sure if he wants to repeat his haphazard flight again this Sunday🥹:(:mad:. He's worried he'll crash it. I'll try to get him to do it again, but if he doesn't, don't blame me😂🤣. Please no more posts trying to prove/ disprove my experiment until the flight test is completed. Thank you! Remember: I it's not even my drone, so I have no control on when and how we fly it etc.
Reactions: Rchawks
The "Moron Setting" for DJI Drones is 31%. Any angle greater than that will shut the Drone off...My GEP Cinelogs will do well over the speed the O.P. is giving, Its attitude at that speed is well above 31%. My Roma Freestyle will do above the legal speed but even below that speed I can easily cook a battery in flight! You certainly don't wanna grab the hot battery after a flight!
I don't overspeed my DJI FPV much, you can smoke the batteries in those very easily!
I did a test on the operating angles: Video1 Video 2 Cheers!
Well yeah, but not 90% of course, and probably no more than 45-55%. Above that the portion going to lift falls off pretty fast 😉
robava
