Do you always have to build FPV drone? Mavic Mini or FPV.
adamkiwi07
Kent
Hi there! Im sure you guys would have seen my threads and alot responded so thanks. I am actually 14 not 16 that was a input age accident. I am wondering wether any of you guys have FPV drone links for UK ONLY. Please let me know. And whats better FPV or Cinema Drone?
Check out our sister forum. FPV Drone Pilots Forum
Reactions: slup
No ... you don't have to build your own quad if you don't want to. You buy a so called "Bind & Fly" which is pre-built and includes FPV camera & receiver... but no radio, no goggles, no charger & no batteries.
But a warning is in it's place here ... you will not get cheaper off going the FPV quad route compared to a Mini 1 you have posted about earlier... that is, if you don't have any earlier needed equipment that you can reuse, such as radios, goggles, batteries & chargers.
Going all new into a DJI digital quad you easily ends up with a cost up to 1300£ ... it's approx equal if you go for a analog system with a equal quality level. Sure you can go with a analog indoor Cinewhoop kit for much less... but that isn't comparable with the cheapest DJI GPS camera drone.
Furthermore the learning curve to master a quad is much steeper then with a GPS stabilized camera drone ... recon you need 20-50h in a simulator in order to not crash it immediately. Then when it comes to footage & stills ... with the DJI FPV system you can get some 720-1080P footage in acceptable (show grandma all the fancy moves...) quality from the liveview, need more you must add cameras like a GoPro. Stills is not feasible.
You have a bit of FPV & Bind & Fly discussions here in relation the rumored DJI FPV kit quad (which will not be cheap when they launch it) --> DJI FPV Combo 2021 Rumors? Where is it? and DJI FPV Combo 2021 Rumors? Where is it?
Reactions: Obsidian Sereniti
LeBeast
