Coolpixel is a screen recorder for the iOS platform. It was a God send when I found it. I used the trial version which records for 2 minutes and that worked perfectly so I purchased the lifetime version for $15.
Well that was $15 down the drain! After you pass the 2 min mark it keeps recording but the video on my iphone 6 Plus starts to break up and stutter. The longer you record the worst it gets. At the 9 minute marker it starts to freeze for 2-3 seconds at a time. BTW my Iphone 6 Plus is a 64GB dedicated device, no apps other than Coolpixel and DJI Go4 running. Wifi is off and it is in airplane mode.
At first I thought it was going to be a simple fix. I tried lowering the screen capture from 1080@30fps to 20fps and even 15fps and at the same point, roughly 2min 20 seconds the same problem. I tried using 720p at all frame rates, same problem. I lowered the bit rate from 5K down to the lowest setting of 3K and tried all of them again, same result. I then tried to turn off the Mavic HD encoding and that made things a lot worst. So In desperation I tried the 480SD at 15fps and 3K bit rate and at roughly just over 2 minutes the same problem starts up.
At this point I can only conclude that this product is deliberately crippled.
If someone with a iphone 7 plus has had different results I would love to know.
I just made this post so that the rest of you don't flush your money down the toilet like I did.
Now I am hunting again for another screen capture program.
I might have to resort to AirShou. I know it works but I would rather not use something that did not come from the app store. Can anyone confirm that Airshou is not a Trojan? Better yet has anyone found an app on the app store that really works?
Rob
Rob
