D droneguy3000 New Member Joined Nov 5, 2022 Messages 2 Reactions 0 Age 17 Location St. Augustine, FL, USA Dec 16, 2022 #1 Has anyone else used Drone Hacks to downgrade their drone to firmware 02.04.2040? If so, did the downgrade pause for over an hour at around 80%? Attachments 2022-12-16 (17).jpg 223.2 KB · Views: 12
Y Yorkshire_Pud Well-Known Member Joined Feb 24, 2022 Messages 4,907 Reactions 4,416 Age 63 Location UK Dec 16, 2022 #2 Might the model of drone that you are working on be needed?
karlblessing Gerbil Charmer Extraordinaire Premium Pilot Joined Oct 17, 2020 Messages 1,213 Reactions 893 Age 43 Location Grand Rapids, MI Site karlblessing.com Dec 16, 2022 #3 I used it without issue, took a few minutes but not hours. If you're on 2190 or earlier it will work, but if you're on the newer one that added remote id (2320), then sadly downgrading is not possible.
D droneguy3000 New Member Joined Nov 5, 2022 Messages 2 Reactions 0 Age 17 Location St. Augustine, FL, USA Dec 17, 2022 #4 It is on the right firmware, I think ill just try again and hope that it works
