engine failure
kruzlifix
hi there
I am extremly happy how my macic pro behaves in the rough northeastern brazilian environement.
but yesterdays gusts were probably too much and my drone fell for the first time off the sky. With its last gps signal, it was easy to locate, one front arm was folded back and its propeller broken
I suspect as cause a uncorrectly attached battery?
it says in the protocoll: problem with energy to engine and propeller problem.
is that indicative of a loose battery connection? it was sending a videostream so IMG_0446.PNG at all time...
thanks for any advice
I'd rather say it means "error: motor current" check prop.
If the prop is not generating it's normal lift the current to this motor will go up.
Maybe the prop was the cause for the crash and not the result?
hi there
is that indicative of a loose battery connection? it was sending a videostream so View attachment 17719 at all time...
Perhaps the arm was not fully extended at takeoff and it folded in during flight. This would cause motor errors as prop would hit the mavic body and not be able to spin.
Maybe you had a propeller hit which caused the prop to break - and then you got the message
NY NICKY
