Failure to download DJI Assistant for MavicAir
JPC
Cambridgeshire
When I try to download DJI Assistant for my MavicAir on my MacBook Pro (macOS Catalina 10.15.5)
Software
platform-mac-88125886e654ae8b885725fad1d50740.svg
Mac V1.2.4
2018-05-16
Download pkg
the system then asks me to also download a "hoRNDIS" application for Android phone. But I firstly I have an iPhone; and secondly the "hORNDIS" will not load as it will not work with my macOS version! And I've tried several times with always the same result.
So I am completely stumped - can anyone help point me in the right direction as I need to reset the visual systems on my MavicAir and need the DJI Assistant to do so.
Thanks
Jon
Software
Mac V1.2.4
2018-05-16
Download pkg
Thanks
Jon
Your better off just installing the latest A2. Should work fine.
https://dl.djicdn.com/downloads/dji_assistant/20200428/DJI+Assistant+2+For+Mavic+2.0.12.pkg
Hi, I've tried that and get this message: Device not Supported.
I've retried the DJI Assistant 2 for MavicAir again and still get this failure problem - why is it prompting me with this when I do not have an Android phone?: I'm using an iPhone SE.
You may want to check out this thread. I believe it may have the answer your looking for.
Good Luck.
Mavic Assistant
Good Luck.
Mavic Assistant
No, I've downloaded the referenced HoRNDIS.pkg and then the DJI Assistant 2 for MavicAir again - but it still tells me to download HoRNDIS and I go round the circle again. I am not as computer savvy as some obviously are on this thread - so a direct link would be very welcome. And is the fact that I have Catalina at 10.15.5 also a factor?
Horndis isn't for connecting to an Android phone, it's for connecting to the drone itself, because DJI uses a fork of Android as a base for the onboard software.
Reactions: JPC
tflys78
