Why wouldn't you just update it?
No, you will get an "inconsistent firmware" warning and then prompted to update.
Connect the Assistant 2 to the Rc,
Open Assistant 2
Connect USB
Turn on RC and wait upto 2 minutes then it should connect then update to the latest release.
You need to do the craft and RC separately, also if you have any additional batteries you will need to turn the Mavic on with those in too and follow the onscreen prompts.
Just make sure each pack is above 50%
The remote needs to be powered up AFTER connecting the USB cable or it's not detected.
