Where, Illinois. Temp, 20. So figured I’d take it outside for about 10 minutes along with an extra battery to get acclimated to the temp before letting everything warm up and do preflight. The gimble said it was under a high load, after trying twice to start up I took it back inside to do the start up and everything worked fine. First flight and everything worked as it should after the warmup. Has anyone else had this problem due to temps? Thanks for the advice in advance.
