- Joined
- Sep 6, 2017
- Messages
- 21
- Reactions
- 8
- Age
- 54
Can you? Yes. Should you? Not if you're concerned about putting unnecessary pressure on the props.My question is if I can keep the props on the drone in the bag that comes with the fly more package
No. They are like the props used on all of the other Mavic drones.Is the air 2 props soft snd bendable like the mm?
I do..
Probably won't help or might make things worse. When quad is folded, there are props under and above the AC. FM case has baffles to keep the AC secured but spaces left to not press on the props on either side of the AC, assuming you have them folded properly that they don't get pressed on by the baffles.On a side note. Why not super glue a piece of foam inside the case right under MM to give some clearance for the props.
Upper props are better supported, the DJI protector straps the tips to the body. Still good to pay attention.Probably won't help or might make things worse. When quad is folded, there are props under and above the AC. FM case has baffles to keep the AC secured but spaces left to not press on the props on either side of the AC, assuming you have them folded properly that they don't get pressed on by the baffles.
Raising the AC in the case may allow a bit more clearance for the props below, but now you've left less room for the props above.
