Fly without data/internet connection ?
Richard Es
Spain
In a few weeks I’ll go to the Seychelles and was wondering if I can fly the mini without roaming/data connection???
Thanks !
yes, you can, just preload map before the flight on wi-fi. I always fly MM in Airplane mode without data.
I fly with an iPad that has no data. Never been an issue here
Thanks !
Contrary to the answer before, you can NOT fly. NOT at all.
But your drone can.
Did a search for current info about loading maps before flight, but did not find other info in this forum.
With the new geo-fencing, isnt the map now required? I have read in other areas maps are required.
I use an old non Simcard loaded phone, so no way to download in the field. How far can I go away from "the download point" for the maps to be relevant?
Geo-fencing usually does not need a map, it needs a GPS signal which then is matched against some internal DJI database.
Besides that I heard recommendations to put the phone in flight mode anyway (to avoid any interference)
NewmanArt
