Flying from a moving boat
Tazshot
Washington State
Flying at sea
Flying at sea
I was recently asked to film a couple of fishing vessels while in operation in the Bearing Sea, near the renowned Dutch Harbor, AK. The first one was a 58-foot vessel and the second was 165 feet in length. Throughout the course of the 6-day expedition, I picked up a few valuable lessons. The first mission, a familiarization flight off the 58-foot vessel, was straightforward. With minimal wind, slow steady speed, no gear onboard yet, and an overhead crane up and out of the way, the flight was easy. I was able to bring the drone in ahead of me and hand-catch it. The only difficulty was the ship's movement, which necessitated constant pressure on the left stick to keep the drone ahead of me.
The initial takeaways from this experience were about turning off unnecessary functions. RTH was set to hover, all obstacle avoidance was disabled, including RTH obstacle avoidance like Avoid and braking if an obstacle is detected. Other considerations included whether the landing would be in the same orientation as the drone, whether the vessel would be stable or stopped, and whether a deck landing was an option or if hand-catching the drone was necessary. In my case, the landing was going to be a hand grab, and I had to face into the drone, which wanted to stop whenever anything came into view. This caused the drone to sit 20 plus feet behind the moving vessel.
The next challenge was maintaining a low enough altitude to avoid all obstacles, including the overhead crane, while also being high enough to clear the guardrail. It was necessary to continuously move the drone forward with the left stick or adjust the altitude with the right. This required the consideration of whether I would be wearing gloves while catching the drone mid-flight. It was also recommended to set the drone to head for home at 40% battery rather than 30%.
Coordination with the crew was another critical aspect. This may seem straightforward, but factors such as crew muscle memory and potential long hours could lead to unforeseen problems. For a two-mile filming event, I chose the Mini 3 Pro due to its extended battery life. The morning flight went well, but landing was going to be the most interesting part due to the small available area.
Things became tricky after chasing the 58-foot vessel for over two miles while shooting a video. The battery was around 35% when the Captain, focused on his next location, suddenly increased the speed. The small working area on the fantail, gear including overhead cranes stretched from port to starboard side, a port side crew shelter altering wind flow, and the need to maintain balance made landing attempts challenging.
Adding to the complexity, the drone, set to RTH to hover, decided it needed to go back to the starting point when the battery reached a critical low. Despite trying to cancel the RTH and asking the Captain to slow down, the drone had trouble landing due to the vessel's momentum and other factors like currents, tides, and wind. Eventually, the drone met the fantail, resulting in a prop strike and a short fall to the deck.
This leads to another point: nothing on a boat that a drone might interact with is soft. Always bring spare blades and remember to update your maintenance record when you change the blade and any post-impact inspections you may have to perform. Weather also plays a significant role when at sea. Fog can appear quickly, winds can change, and the boat's direction may shift.
The next vessel provided a good place to launch and recover on the forecastle deck. However, it came with its own set of challenges: pieces of equipment, railing almost 6’ above the launch point, a 195 Ton vessel chasing you down once airborne, and magnetic interference. The adrenaline rush is real, but with over 60 hours as a private pilot and more than 100 hours as a Remote PIC flying various drones, I managed to calm my nerves and safely retrieve all drones.
Obstacle avoidance and RTH are not always your friends. However, Atti mode is a great ally that will bring your drone to you wherever you are at that moment. As Randy Pausch once said, "Experience is what you get when you didn't get what you wanted. And experience is often the most valuable thing you have to offer." You can check out some of the footage I shot on my Instagram under "Tazshot".
You provide a great description of the challenges of flying at sea on a moving vessel. Definitely not a challenge alot of pilots would want to attempt. Well done!
First thing - paragraphs make reading a lot easier.
Flying from a moving boat is much more difficult that any landlubbers can imagine.
Congratulations on doing it successfully.
A critical low battery the drone decides it needs to go back to starting point so it can Hoover as selected in the setup.
To prevent this potential problem, you need to reset the home point a few times during the flight, to keep the homepoint near the boat, rather than back where you started.
The drone is constantly monitoring the battery level and distance to home and when it calculates the battery is just enough for that distance, your time is up.
Reset the homepoint to either the drone's current location of the controller's.
It won't matter which.
magnetic interference (compass calibration held high does work
There is no need to recalibrate the compass, even if you think the drone is telling you to.
DJI's warning message is very badly worded and confusing.
Your compass is warning you of magnetic interference (nearby steel).
The solution is to turn off the drone, move away from the problem (steel object too close to the compass) and start again.
Flying at sea
Pardon the intrusion, seems that ChatGPT decided to automatically interject and make the text more readable (above).
Nice photos. I do agree you should break your post into paragraphs for better reading.
I have a friend who uses this thing to launch and catch when they are on their boat.
On a stationary boat, especially where you have the option to land with out having to compensate for current or speed of the vessel which was not stopping might be an option. Not sure that this would have helped given the situations I was facing.
That was an adventure , you might consider getting the Rescue Jacket that would allow you some leeway both landing on the boat, hand catching and keep your drone afloat if it went in the water.
What I advise my clients is that you Secure the Footage you need first with the Rescue Jacket , than if you dare , go wing it . Nothing will upset a paying client more than loosing the footage.
Phantomrain.org
Gear to fly in the Rain and Catch your drone safely from a Boat.
Flying at sea
Flying at sea
View attachment 166718View attachment 166719
Great article. A really interesting read and two fantastic shots of the boats.
Flying at sea
Flying at sea
This is the post my search engine found first in response to "flying a drone off a sailboat" and it's a beauty. About to purchase a DJI Mini 4 Pro for use on an Atlantic crossing on a steel sailboat. So my first few hours of flying will be mostly hand catches. Thanks. I look forward to learning more...and getting insurance.
The Mini 4 Pro is not the best drone for this, I would get the Air 2S at Min , you can than get some better accessories for hand Catching as I placed in the Post , have more power , and do a lot better in the Wind.
Phantomrain.org
Gear to fly your drone in the Rain, and Increase your VLOS and land safer .
Man its hard enough flying from the ground. Awesome thread. I dont know what a paragraph is so dont change a thing.
Sweet photos by the way.
Flying from a moving boat introduces complications that land based flyers can't understand.
You'll need to get to know your drone properly on land - learning basics from a boat would be asking for trouble.
That your boat is steel will create additional issues.
Don't even think of launching from the deck.
You'll have to hand launch and catch, preferably when the boat is not moving.
Reactions: svalchemy
And moving means in any direction including up and down. If the deck rises and falls the done will try to maintain altitude once the propellers have been started.
So I assumed. Thank you. I have other steel boat pals doing this successfully, however. RTH has to be disabled, I know that much, and a friend suggests "backing in" over the stern. Other tips and tricks await. If you are concerned about steel, I assume the drone has an integral fluxgate compass and you are concerned it will be overwhelmed by proximity to the deck?
The biggest worry is that you cannot manually switch to atti mode.
Because of this when launching or catching, if the boat is moving, as soon as you start up or grab the drone, it will fight against the movement, attempting to hold position.
You can think the boat is still in the water, but if the water is moving with any current, as soon as you grab it, the drone will rev up and try to get back to where it was when you grabbed it.
Maybe that's not a big deal with a Mini, but with a Mavic 3 or 4 it's very scary.
I will try to find a patch of soft grass to practise hand launchings, I think. The sudden fatal "exceptions" I'm reading about are spooking me a bit.
There are Two very Effective ways that makes flying your drone safe on the Boat.
The First is the Rescue Jacket \\that we make for the drones so you can hand catch safely and land in the Water if need be.
The Second is what we call the Lunar pad , designed to Reach out to your drone and land if Safely while moving with Precsion , The Difference is reaching out to the drone is much safer than trying to land it in your hand,
An example of the Lunar Pad in Action to show how this works .
You can get them with the cut outs or without , they come with a Wet Suit or you can make one yourself.
Phantomrain.org
Gear to fly in the Rain.
dvkhamtruocsinh
