Flying the sky over San Antonio, Texas
Rip-Lash
San Antonio, TX
I’m an excited new DJI Mini SE owner. I‘ve loved drones for years and tried building them back in 2013, I was a horrible FPV flyer. I couldn’t afford a DJI at the time. Now I can afford one, so I entered the DJI addiction with the DJI Mini SE. it is amazing for the price. It’s amazing technolog. Ive had it since mine December 2021 and already have another model “upgrade” in mind. I have a few questions so I’ll search around here to see what I can find on the topic. I look forward to sharing and learning within this community!
Hello from the Crossroads of America Rip-Lash.
The MINI se may not have to be registered with the FAA, but if you haven't done it yet, you should take the TRUST test and keep a copy with you when you fly.
Good luck and welcome to the Forum. :cool:
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome to the forum! :)
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
Hi there Rip Lash - I am still waiting for my Mini 2 to arrive but am scouting out sites to fly - have been having a hard time finding open fields in the NW part of town without too many trees that I can use - I live by the RIM, any ideas? An empty football field sounds great! :) PS WHat are you doing about flying in the HEAT!! thanks! Alex
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Living in San Antonio, Texas, there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy and Safe Droning…
FAADroneZone
Great info, thank you for sharing!
Reactions: Gagey52
Greetings from Birmingham Alabama, welcome to the forum!
paul44509
