Flying with a broken propeller above Tartu ?
Proffy
Web
After few minutes of flight, Mavic Air start to act weird, continue its movement, instead of just hover on a place, tilting when flying, once its landed I found a crack (approx 7mm long) in a prop. After a lot of cropping I still able to compile a short movie about Tartu. Yay! :)
Not that I’m aware of.
I have several DJI products and (knocking on wood) have not had any of those issues.
Reactions: Proffy
Here's a pic a of a crack:
I’m surprised that caused the flight issues you describe. I have inadvertently flown with props in far worse condition and not had any issues.
I would perhaps, as a precaution, review the flight logs to see if there were any other issues. It may indeed have been the prop but there may be a hardware issue with the drone.
Nice footage either way :)
Reactions: Scott99205
Odd. I would lean towards damage during handling or transport. Is that a possibility?
Unlucky or extremely lucky depending on your viewpoint.
Glad to see you landed safely.
Thanks! Definitely Lucky. Replacing props is much cheaper then replacing drone. :)
Reactions: Thomas B
Khm... In that case maybe it was caused by compas glitch or something like this? Yeah, I’ll better check the flight logs
Great video! Who would have guessed there was a prop issue, nicely done! :)
  • Love
Reactions: Proffy
I had a crack Similar to that on my Mavic 2 and it happened while landing on my landing pad one of the rear props hit the stake that holds the pad it was a new prop but changed it anyways
Reactions: Proffy
Sad to hear. Anyway, now I check props even after flight :)
djiNonMini
