The iPad Mini will fit in the remote controller arms like this:Question for those flying with a Mini4, do you have the arms hold it in portrait orientation, or did you get a holding frame, and if so, which?
View attachment 32025 I was using the arms of the RC at first. Then I switched to the Mavmount and like it better. The thing with using the arms on the RC makes it difficult to get to the sport mode switch on the right side.
But if you don't want to deal with an adapter, the mini 4 is the way to go.Why bother with a Mini 4 if you're going to have a mount? The whole point is to be portable, and using that mount 100% defeats the purpose. Also, the Mini 4 is inferior to the 5th generation iPad and iPad Pro by a significant margin, along with a much smaller screen. Considering you could just buy a 5th gen iPad for $250, not even cost is in the Mini 4's favor, so there's no reason to bother with a Mini 4 if you plan on buying a mount.
I got the Mini4 because it fit into the jaws and did not cover up the RC screen.
Got an IPad Mini 4 as soon as it became known that the Mini 2 was causing video breakup on the Inspire 1 & P3P I also own. Have always used the Mini 4 with the Mavic as it's a fantastic fit with an 8" right angle cable. I almost cry when I have to use the bulky controllers the other drones use. In short the Mini 4 is the perfect companion to your Mavic period. My only concern is Apple not making a newer version and the Go App becoming too much for it meaning the old Mini 2 problems coming back. I also keep an IPod Touch 6 handy as a backup which is also very good if not small.
