FN Button problem
photo2be
Stockholm Swedem
Do you think the FN button to switch to MAP doesn't work indoors with NO sats found?
Hi, BOFORE I updated to AC 01.01.0700 / RC 02.00.1101 the FN button was set to Toggl Map / Live W worked perfect. With current update nothing happen when I tap or dbl tap the func button. Besides that the RC is screeming. In the FN setings there are "TAP" and "Double Tap" What should I use.
All help is apreciated.
I use one tap to toggle to map and back, double tap to re-center the gimbal... if that is what you were asking.
By screeeming to you mean non stop beeping?
Hi, its just screeming when I push the FN button. Nothing at all happens when I tap once or twice.
Jeremy Green
