Funny screen when trying to use Quick Shots
Flow
Bavaria
Hi everybody. I am new user of a Mini2. When I try to use Quick Shots (each of them) I got a funny screen (on Sony Xperia mobile) before I can select the target frame.
Here it looks green, outside it looked brown with other colors.
When I scroll the Gimbal up and down screen becomes better in some parts, but then it goes back to this pattern.
Does someone know what it is or could be? Thanks.
First step would be to delete the DJI Fly app from your phone and reinstall with a fresh copy..... often this method will fix odd behaviors.
Reactions: Flow
Thanks Saladshooter.
Will try if I must, but I am worried not to be able to install DJI Fly App again (because it´s only available as APK-file).
APK files are not hard to install... we can guide you through it if you need.
Reactions: MS Coast
Yes, could be easy with a mobile phone recommended by DJI, but I don´t know for sure about my Sony Xperia. I think this fly app I have from play store a while ago.
If you are still using the Play Store version then that's the problem. You definitely need to delete that old version and download directly from DJI's Website! It should install no problem, as any other APK file.
Reactions: Flow
dvkhamtruocsinh
