Hey all, so I've jumped into the hubby 'hobby' now with a new
Mini 3 Pro.
mavicpilots.com
Since you live in Hong Kong, there are specific laws and rules for you to follow, please check to ensure these are current.
According to HKCAD, drone use is allowed in Hong Kong, subject to HKCAD regulations. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
