Getting B&W diagonal bars on white images
Sunshine
Montevideo, Minnesota
Wondering if anyone knows why I get diagonal black and white lines on most white objects. The lines are very straight and evenly spaced. I haven't seen them show up on photos taken but gets annoying while trying to frame a shot.
Also wondering how large of a print one can expect to make from a still photo made with the Mavic...I would like to make at least a 16 X 20 Thanks !
Someone will chime in to correct me but I believe that is either overexposure warning or white balance, it can be disabled in the camera setting menu (or one of the menus.)
dji-go-over-exposure-setting-jpg.10085
Reactions: MrsTreat
Those lines are showing you the areas of the image that are over exposed. You can hide them via the setting above.
I tinkered with some of my settings and had the same problem with the vertical lines showing up. Logged onto the forum, found this thread and fixed the problem in minutes. Thanks for the help and keep up the good work.
Were the lines similar to this issue? I have not fixed mine yet, what settings did you change?
You can remove those lines by disabling the setting in my screenshot above.
tagir
