- Joined
- Oct 26, 2016
- Messages
- 926
- Reactions
- 706
So, as I've posted here I had a new M3 that was doing a bunch of crazy things. Most concerning was landing where I took off at over minus 100 feet. Few other things were flying along in a straight line and start descending or ascending without touching the stick. Multiple times the drone would not go faster then 10mph unless I switched into sport then back to P mode. I requested support CASE NUMBER 3896876 from DJI about 2 weeks ago and till now have received NOTHING. I did get one message passing me along to the "team that deals with this". A few folks that saw my logs agreed there was a real issue here and the drone needed to be replaced. So I returned the drone to the place of purchase for a refund and ordered elsewhere (couldn't exchange as dealer had no stock).
New drone arrived and is doing the EXACT SAME THING. So. How can this be. Odds would be astronomical that I drew another bad drone..So with no help from DJI not sure what I can do other then return and get the great Air 2S again. I've been flying for 6 years almost every drone out there and logged nearly 7,000 miles. I fly almost every day of the week and 98% in the same area. I've tried everything I know. I changed areas, locations, calibrations etc and I'm stumped. Would appreciate the experts here maybe having a look at my logs and weighing in as to what they think could be happening here. As for my hunch I believe it has something to do with the vision sensors. I do fly a lot at dusk although issue happening in full daylight but not as bad.
Here are a couple of logs. This first one is from the returned drone where the flight lands at minus 110 feet
This log is from today's flight, just a few hours ago. Please have a look at 1m 38.5 you'll see drone start dropping in altitude with the left stick neutral. At 1.38.9 stick now up as I try and correct descent and altitude still dropping a little bit more. Finally 1.30.3 where VPS shows altitude at 48.6 feet and the IMU shows 80.4 feet. This is the point the readings stopped being close.
Thanks
DJI Flight Log Viewer | Phantom Help
Upload and view flight logs from your DJI drones
www.phantomhelp.com
www.phantomhelp.com
Thanks
