Hi,
Since I've purchase my MM less than a month ago I've use it a lot, 5.93 hours and 35,3km distance, no problems until the last 3 days. Now, almost every time I fly it, I get the "Gimbal stuck 40002 Error" and sometimes the gimbal overheated message too.
At the beginning sometimes just switching all off and switching in on again solved the problem, but now I am calibrating the IMU and compass every time it get stuck, this usually works fixing "temporarily" the problem, however is very annoying to have to do this several times a day every time I arrive to a different locations to get more footages.
I am also calibrating the gimbal once or twice a day.
No need to mention how bad it is when I am filming in the right place and suddenly the gimbal start doing funny strange movements. It is happening too many times now, not happy at all.
Before this problem started most of the time I calibrate the compass before every fly, but almost never the IMU as long as I was getting a message asking to calibrate it.
I am afraid there is a problem and I wonder if this is a defect that maybe many Mavic Mini has from factory. Do you guys know something about it?
If I would be at home I will definitely take it to get check right away, however I am travelling abroad and I will still be one more month away of home, filming with the Drone everyday. It is extremely inconvenient if this problem continue or get worse, this would really ruin my trip.
Any suggestion?
Thanks in advance,
Hugo
Any suggestion?
Thanks in advance,
Hugo
