GPS Tracker is Relevant
I've not yet tried Marco Polo yet but can i ask you a question sir msinger? Can i locate my drone using via Web, iOS, or Android app?
This is a radio tracker, so it's not possible to see its location on a map. You need to manually locate the tracker like this:
So this is how marco polo works .. Ahh marco polo uses radio tracker, while trackimo works excellent in real time tracking. Thank you for your info about marco polo product sir
I would guess that the Marco Polo tracker would in fact be a sort of real time tracker in that the little arrow
on the display will (should) always point pretty much toward the drone even as it is flying
Well i am satisfied with my trackimo 3G GPS tracking device :)
As long as you are not in the bottom of a canyon or in dense forest and able to get good GPS coverage, Trackimo would be fine.
If the GPS or cellphone coverage was poor or non existent, you would have to rely on an RF radio tracker
I am sure installing a tracker gives people more confidence to fly.
I have now covered 2800km with my mpp without a tracker and all my flights are way beyond los on private property. So far the quad never went into ATTI mode, or disconnected from the RC. The app has disconnected a few times but that does not make the drone fly off into the sunset.
Losing your drone due to the app alone crashing is not going to happen except when you panic and do something silly.
I also find it highly unlikely that the craft will go into ATTI mode while the app crashes AND your remote control disconnects, all at the same time. But I could be wrong.
Reactions: ryanolivas
Trackimo use 4 different technologies to accurately Locate anything Worldwide. GPS utilizing Global Positioning Satellite technology to locate outdoor within 30-150 feet (10-50 meters) accuracy. Wi-Fi is used for indoor tracking and Bluetooth for the last 10-60 feet (3-20 meters).
realdealathletix
