I am a newer pilot, have
Air2S w/ RC Pro Remote.
mavicpilots.com
Since you wrote that you you relatively new to droning, now, for the Fun Part; FLYING…
But do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
Learn and download DJI
Air 2S related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
