Greetings form North GA
dpstk78
Watkinsville, GA
Hello, I am a first time drone owner. I came into the Mavic Air Gen 1 and so far love it. I am still learning all of it's features. I joined this forum to hopefully link up with some of you that are experts and are willing to teach a newbie how to get good at this. Anyway, I am glad to be a part of the community!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Hello from the Crossroads of America dpstk78.
If you haven't done it yet, swing by the FAA and register the aircraft.
You should also take the TRUST test and keep a copy with you when you fly.
The registration is five dollars (US) and the test is a no fail that's free to take.
Good luck and welcome to the Forum. :cool:
Welcome to the forum. Just down the road in Roswell, GA. We look forward to your participation and your view of the world.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
That's great that you have already met all your legal requirements, you are off to a great start. Now for some sage old advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air. You will also find the 58-page User Manual, in case your Drone did not come with one.
Mavic Air - Download Center - DJI
Happy and Safe Droning…
Welcome to flying and the forum from the gulf coast of Texas!
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response!
Welcome to the forum! :)
Weepo67
