Greetings from Austin, TX (USA)
RRDC Media
Austin, TX, USA
Hi all,
I bought a DJI Mavic Air in early 2019 and after a vacation in Bali, Indonesia it got damaged by water/sand. After that I hadn't used the drone for years but this year I've started using it again and now I'm obsessed! I usually go flying in the weekends and am currently working on a compilation video of the city that I currently live in (Austin, TX). I'm definitely not an experienced drone pilot (~25 flights) but I'm getting better and I'm here to learn and get some helpful tips.
Thanks,
Ricardo
Greetings, Ricardo, and welcome to our forum from the friendly skies of North Texas. Yeah, the same state!
We are happy to have you with us. We have over 150,000 members worldwide (including many in the Austin area) who enjoy helping each other learn and grow as pilots and photographers. Anytime you have a question, just ask!
Rich R (alias Hauptmann)
I bought a DJI Mavic Air in early 2019 and after a vacation in Bali, Indonesia it got damaged by water/sand. I'm definitely not an experienced drone pilot
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Fly On and Fly Safe…
The link to the Texas laws (and other states) is very helpful! Also these tips above are very helpful to me and I'll be sure to follow these, thanks a lot!
Welcome to the forum! :)
cbooth
