mavicpilots.com
@MA2 317 has already given you’re the heads up on the TRUST and Registering your Drone if you want to so please take it to heart…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Idaho, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
At DJI Download Center, Learn aboutMavic Mini
www.dji.com
Happy Droning…
