Has anybody seen this red Icon before?
k9kids
Dallas, TX
I saw this icon while flying using my iPad Mini. It disappeared before I could capture a screenshot.
Tonight I was using my iPhone SE 2020 and the icon appeared while the Air 2 was sitting on the ground. It also disappeared and all went back to normal.
It makes me think the controller isn’t seeing the display device. Looked through the documentation but didn’t see anything.
Reactions: Parrotoid
I have it all the time. I've been recalibrating the phone's compass. I'll do the drone's.
And it did not help.
Oh man, I can't remember what it means but I think @Ice_2k knows
I had the same question a while back, got answered. Just wish I could remember where to point you.
Might be a weak GPS lock, don't want to provide misinformation though, so don't take that as fact please, unless confirmed.
It means the Russians have hacked your phone.
jk.
It just means that the compass is having some issue on your phone. I'm not sure if it's a bug from DJI's app or not, because if you open the iOS compass app this works perfectly fine.
I’m using iPad mini 5. No compass on it I know of.
Mine quit working when i got a replacement ma2 and started running 1.1.5 . Crashed 1st one was working great on it. Replacement has never worked. It shows approx where in front of you it is and the orientation of the drone comparison to you. I found it useful.
That icon has appeared many times on my phone while im flying
Yep. I had it a few times. The app is telling the you that the compass needs calibrating. Problem is...there is no compass in the wifi only model. I need a wifi/cellular version.
It means the app can’t get good compass information from the phone (either that or the drone doesn’t yet have a good GPS lock but that’s not the case here judging by the top icons)
personally i dont ever use it as i have a WIFI only ipad it never gives an accurate reading ,even when its white so i just turn on the map and use that to show my direction from the home point
I’m new and never even noticed it until it turned red. So I guess I never used it either. I’m seeing 15 satellites so I think I’m okay.
Reactions: Motorcycle Rider
It didn’t work at all for me with the Mini but it works perfect with the Air2. Looks like the different remote design is a better fit with my phone’s compass (iPhone 11 Pro). However, the fact that this is visible only when not showing the map in the bottom left makes it useless to me as I always want to have the map visible
I’ve gotten that a few times with both my Mini and my MA2. What I’ve found is that I have the RC and phone too close to my body (I usually have my controller near my belt line) and I think the belt buckle may be causing interference with the phone compass. Usually if I move the controller away from the buckle or pick it up higher above my belt, that icon goes away and returns to normal. Luckily, I’ve never had an issue the AC acting differently when that icon is red
Thoughts?View attachment 106090
What app were you using when you got this icon? Jim
elitewikipublishers
