Has anyone got video shaking like this?
Sparky
Siskiyou Mountains in Southern Oregon
For the first time today I tried going into sport mode on the Mavic Pro and noticed severe shaking of the video. I'm using a Nvidia shield K1 for the control tablet. Also using the new low noise props. Normally in non sport mode the video is much smoother. Update, just found out this effect is called "Jello" now I see a number of posts on this. Any advice appreciated
This first part of this video is flying in sport mode showing the shaking, the last part is not in sport mode trying out a point of interest which it did without the video shaking
Are you shooting 4K? I see that you are recording in auto mode. You might want to try going manual and seeing if things change. Your shutter speed is really high. You might want to get a set of ND filters to bring parameters into a saner range. Typically you'd want your shutter speed to be as close to twice your frame rate as you can get. Keep the ISO low 400 tops and then experiment ND filters until your shutter speed is about 2x the frame rate. You're also flying really fast when you're in Sport mode so this could also be an artifact of gimbal shake from being buffeted by the wind. You'll just have to play around with it and see what works. I'd try getting the speed down and the camera parameters in line.
How do the actual video files look, that looks like a video for your flight stream
JefScot
