Having serious toilet bowl problems
shaneb50
union sc
Greetings everyone . my mini 2 drone is having problems often and will toilet bowl effect and just go out of control.
I have tried everything from calibrations both compass and imu. But nothing. My only option left maybe is try a total propeller change or just send it back.
If I have missed anything please let me know. I'm thinking it will need a new replacement. Fortunately I have a backup mini 1 drone to use until the mini 2 is fixed or replaced. Thank you so much and God bless.
Propellers aren't the answer because they don't cause that sort of thing.
Can you describe the issue and post some recorded flight data.
Reactions: maggior
Hi ok when I fly sometimes it will start to move in small circles , then it behaves uncontrollably by going left. Sometimes a recalibrate Will fix it for a bit.. I will post a flight record soon. Thank you so much
In this case, also, drone is regularry asking for IMU calibration when outside.
All such cases indicates some problems with IMU or compass. Since IMU is not officially available as part, only resolution here to apply for warranty replacement or repair.
Laki
