Hawk. Crash. Advice???
jeffreydepp
Cleveland Ohio
Crashed. Hawk attack mid air. Gimbal seems to be broken off the plate? Any advice???
I personally wouldn't send it to dji
If you arnt confident then I'm sure thunderdrones will sort you out
Parts can be obtained from eBay, Amazon or thunderdrones
I would get the plate and ribbon, not changed a plate but it looks easy, ribbon isn't difficult just fiddly
Be careful when disconnecting the camera assembly as I accidentally damaged one of the vision camera ribbon cables
Search YouTube for gimbal ribbon replacement so you know what's involved
Reactions: jeffreydepp
Do all the other wires in my photos seem ok?
I just turned on the mavic and all seems to be working and camera seems fine... just can't move around because it isn't screwed to the plate (broken off)?
If you have video then the video cable is fine
It's hard to tell from a picture due to micro nicks in the cables can stop it from working but won't be Visible in a picture
One of @Thunderdrones pictures
Reactions: Guest232
My gimbal looks exactly like that after my tangle with a tree the other day. I'm also looking into what exactly I broke so I can fix it. Good luck buddy, I'll be keeping an eye on this thread as I'm sure I'll get good info on the help I need too.
Same page has both the ribbon and plate $30 upto you if you want to chance it
Change both and have peace of mind
Change just the plate and likely need to disassemble again and wait for another delivery
Reactions: Oconnb910
Since I'm not sure of the level of damage yet, if it turns out I need the plate I am definitely going to get the cable too. I'd hate to change the plate and get it all back together only to find out the ribbon is bad too. My luck is not good so Im not risking doing that to myself.
RYNOGOD
