Is there anyway to change the settings so it will show the height & distance when you take a photo or video on a MM?
If you want to know where you shot a photo or how high the drone was, that's easy.Is there anyway to change the settings so it will show the height & distance when you take a photo or video on a MM?
Expand on that for me please. Wasn’t aware the elevation info was in the mix.Every still image file contains metadata
Following data can be retrieved from the EXIF:Expand on that for me please. Wasn’t aware the elevation info was in the mix.
This EXIF field is AGL (right above the Take Off point)Note that this height is in reference to height above the takeoff point, not absolute or above ground.
