Hello all from Denton, TX, USA!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
New pilot. Mini 3 Pro. Contemplating Section 107.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a newbie Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) Your Drone weighs less than 250-grams (0.55 pounds) so you are flying under The Exception for Recreational Flyers, so you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you have a YouTube Channel that pays you anything… You will need to acquire the Part 107 License. If you are only going to post the videos for fun with no payments for YT, then you are cool., otherwise, if you are considering acquiring your Part 107 License, here is a link to get you going…
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Welcome to the forum from the beautiful woods of Maine!
Reactions: GFields
osje
