Hello from Cincinnati area
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I’m a pretty new pilot. Got my first drone, a Mini Pro 3 last month, and just passed my part 107 exam last week.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, remember this, the only dumb question is the one you do not ask… Now, with that being said, that does not mean we will not make fun of your questions, but it will get answered…
Way to go on that Part 107, but since you are a newbie, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
marcusjohn3684
