Hello from CT
Welcome to the forum! :)
Your picture?
Wow looks like you have all ready been flying open cockpit planes. :)
My dad is a pilot, its not my thing, we have a Major Aircraft and etc Museum here and he volunteers a lot. I won't reply here for questions.
Just commenting on your picture.
I bunch of good members here!
I almost forgot, Welcome to the Forum!
Rod ..
new member and new pilot here from CT
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Connecticut, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Thanks for the welcome and all the advice everyone!
Rod, nonono, thats not me, the pic is from Mr. Deeds.
LordThunder, I do have my Part 107 and TRUST. Also, picked up a refurb Mavic Mini 2 from DJI which I have not flown yet. I've gone through most of the tutorials on the DJI Academy. I'm currently working on figuring out where I can fly around the Northwest corner of CT before I fly. I'd rather be grounded and learning than flying and in trouble.
Thanks everyone!!!
wang
