hi, i,m new here and i fly with a mavic 3 classic
thnx for the usefull advice.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
Since you live in the Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones for residents of the European Union
As a resident of the European Union (EU), you may fly with your drone in the Netherlands. If you fly in the OPEN category, you do not need to ask permission for your flight(s). However, please be aware of EU or national limitations that apply. For drones and drone flights in the SPECIFIC...www.government.nl
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 3 Classic, including the User Manual.
DJI Mavic 3 Classic - Download Center - DJI
Learn and download DJI Mavic 3 Classic related apps, software, and manuals at the DJI Download Centerwww.dji.com
Fly On and Fly Safe…
Hey, nog een Hollanderhi, i,m new here and i fly with a mavic 3 classic
Welkom vanuit Montroy Spanje, ik denk dat je op dit forum je draai wel weet te vinden, succes met je Mavic 3 Classichoi, ik ben nieuw hier en ik vlieg met een mavic 3 classic
