hello from Kirbyville, Mo. Usa Population 207 MA2 first drone
Flying Skwerl
Kirbyville, Mo
Just got my first drone, Mavic Air 2 and what an expense these are! But I pulled the trigger anyway. I will be here often taking advantage of the group's wealth of knowledge. See ya in the forums! I already have a great crash video. The prop guards took a hit, but the tree was not left unscathed. Props chopped a limb about 1/4" thick on initial contact. No damage to the drone, although it fell limb to limb from about 50 - 70 ft up. BAD NEWBE!
Hello from the Crossroads of America Flying Skwerl.
If you haven't done it yet, swing by the FAA and register the aircraft.
Then take the TRUST test and keep a copy with you when you fly.
Glad to hear the MA 2 survived the incident.
Usually the gimbal gets wonked. That's what happened to my Spark a while back.
Welcome to the Forum. :cool:
welcome to the forum well you have already had your first encounter with the drone flyers no one enemy the dreaded tree
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Even living in such a small community as Kirbyville, population 213 (I thing mrs Smith's cat had its kittens…), there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…) FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Link to the FAADroneZone (Optional for Drones under 250-Grams…) FAADroneZone
These are your words, "BAD NEWBE!"
Below is the link to all of the downloads offered by DJI for the Mavic Air 2. You will also find the 57-page User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Happy and Safe Droning…
Welcome too from the U.K. That crash sounds pretty significant and you were very fortunate to have the guards on. I have a set but don’t use them-there are folks on the Forum who think they are heavy and cumbersome. Seems yours saved you from more expense.
Welcome to the forum! :)
Welcome to the forum from Chicago the Windy City.
You can look at Mavic Help, Loud Thunder gave you good advice.
It's not just book knowledge, its application of what you learn.
I know a fellow with 4 masters degrees, but he has no common sense.
yeah, I just dusted it off and it was ready to go again. Here is the crash video link
lab916
