Hey Jord,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Down Under, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CASA, drones are allowed in Australia for recreational and commercial use, subject to CASA regulations. Read on for details.
drone-laws.com
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
