Hello from SoCal
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
I’m a new pilot in the northern Los Angeles area flying a Mavic 3. Looking forward to meeting and flying with new people!
HEY!
Hello from Savannah, GA!
I have an uncle that lives on Hermosa Beach. Did I spell that right?
It's a tiny little beach house but he says it's worth a mint. lol..
I'm his only nephew. ;)
Greeting from So. Orange County (Aliso Viejo - San Juan Capistrano)
We're not really neighbors, but you're the closest I've noticed on these forums.
Mike Allen - Mavic 3 Classic
3 weeks ago did a 4.7 mile flight each way from Dana Point Marina to San Clemente Pier and back.
Hoping you get some beautiful footage in Santa Clarita!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Greetings mate, welcome to the forum from the outback of Australia. Look forward to your input.
Regards
Welcome from another Los Angeles based drone pilot
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Mamanov Ramazan
