Hello from southern Utah
Gramps44
Central, UT, USA
I have been wanting a drone for a long time. My son bought the Mavic Air 2 fly more combo for himself about 1 1/2 years ago. He lives in the big city (southern California) and found there isn't much area to fly it. I live in the mountains of southern Utah and have 1000's of acres to fly around. This past weekend my son and his wife came to visit and while he was her he gave me his complete drone package!!!!! Now I have a big learning experience in front of me. I slowly found how to change the registration and drone name (no help from DJI). Now my main plan is to learn how to fly it without loosing it in the trees. I found the "find my drone" in the app on the smart controller but I'm thinking I might want something with more battery life thats independent of the drone battery..........Marco Polo????? Not cheap but I hear good things about them. With all of the hills, mountains and trees here I think this might be the way to go. I want to fly around and in the trees looking for deer antler sheds so crashing might be an issue. does anyone have any thoughts on the Marco Polo unit??
Hello from the Crossroads of America Gramps44.
You mentioned registration, is that the FAA registration for the MA2?
If you haven't done it yet, swing by the FAA and register the aircraft.
You should take the TRUST test too and keep a copy with you when you fly.
I've always wanted a Marco Polo for my Spark, but I never purchased one. Since I fly within VLOS, I figured I wouldn't need one for my MA2.
Have fun with your new hobby and share an aerial picture of your fire trucks. 🚒
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!
Hi Gramps,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and if you continue flying under The Exception for Recreational Flyers, you are still required to register your Drone.
There are many, many YouTube Videos to explain and show you how to do almost anything and everything to and for your new Baby…
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Utah, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Gramps44
Welcome to the forum! :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings Gramps, welcome to the forum from the outback of Australia. Can’t help you with the Marco Polo, I see people are using an AirTag with their drones. The only draw back with most off those devices is that they must be in internet range.
Regards
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Hello southern Utah is one of my favorite places to fly. You live in a nice area for droning!
Use your smartphone to hotspot to the Internet…
  • Haha
Reactions: Gagey52
Not true. You don't have to have the internet for them to work. I know, I've been in some very secluded places definitely without internet, data or phone, and flown them around without issues. Not sure you even need satellites or GPS, although I think they come in useful. For example without GPS I'm not sure your drone could find its way back if lost.
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
dojin23
