Hello from Tuscaloosa, Alabama
Welcome to the forum! :)
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .
0rojyyg-png.95983
Greetings from Birmingham Alabama, welcome to the forum!
New to the Drone world….
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2. Have you bought a Drone yet or are you still trying to figure it all out?
If you are flying a DJI Drone, let us know what you have and we can hook you up with some links that you may not be aware of…
Inquiring Minds Want to Know…
Sorry for the delay in my response. Yes, I have a Air 2S. I would love to learn more so please any helpful links. I’m looking at 3rd party apps like Litchi, but very nervous.
Glad you responded and I hope you don’t get too "linked" out… But here's a bunch…
I do not use the Litchi App, but a lot of member's do so check out the Air 2S Forum. Also there are lots of YouTube Videos on the subject. But I'm of the mind that you need to learn to fly your drone yourself verses letting an App do it… Hence, the long list of advice that follows…
Again, we have a Member's Map in the Upper Right of the Title Bar, check to see it you are listed and where you want your "stud" posted…
As a New Drone Pilot, there are a couple of Legal Things you need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and you are required to register your Drone.
Link to the FAADroneZone (You need to register you Air 2S…)
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy, Safe and Legal Droning…
jhon65
