Hello, new Air 2S pilot here from Yorba Linda, CA. I am editing my photos and video with the Adobe Photo Suite. Looking forward to be part of the community and learning as much as I can. Thanks!
Thank you, I took the trust test a week before the drone came in and registered it the night I got it. I make sure I have them both when I fly. I'll be starting the a Part 107 program soon. Any recommendation?Hello from the Crossroads of America JV Flys.
If you havent done it yet, swing by the FAA and register the aircraft.
FAADroneZone
faadronezone-access.faa.gov
Also, you should take the TRUST test and keep a copy with you when you fly.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.trust.pilotinstitute.com
Good luck and welcome to the Forum.
Thanks for the advice I appreciate it. I am still a pretty nervous flyer so I follow those steps and more! LOL I am am a technical person though and pick on on tech stuff pretty quick so I am making fast progress. I never rush the set up or packing up. Having fun so far and just bought my son a DJI Mini SE so he can join in the fun too!Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
As a New Air 2S Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
FAADroneZone
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Online Ground School: Aviation Classes - Pilot Institute
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.pilotinstitute.com
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Drone Laws and Best Places to Fly in Every US State - Pilot Institute
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
DJI Air 2S - Download Center - DJI
Learn and download DJI Air 2S related apps, software, and manuals at the DJI Download Centerwww.dji.com
Happy Droning…
Greetings from Colorado, welcome to the forum.Hello, new Air 2S pilot here from Yorba Linda, CA. I am editing my photos and video with the Adobe Photo Suite. Looking forward to be part of the community and learning as much as I can. Thanks!
