Hello there!
Indianapolis, IN, USA
Hey there,
I’ve had some experience with cheap sport drones, but this weekend I bought a Mavic Air 2 off of a buddy. That night I registered and got my recreation taken care of and I’ve gone on a few initial flights so far. Man, what a difference it is flying a quality quad vs the cheap POSs. I’m still learning to trust the equipment, however I’m extra paranoid since it’s used and I can’t get any refresh care on it. But I’ve done some testing on the RTH and had a low battery RTH this afternoon that worked as well as I expected.
I’m working on getting my 107 because I’d like to have the option to make some part time money off of this. I’ve been a wedding photographer in a previous career and I’d like to avoid that level of involvement, but I’m seeing other possibilities here. Does anyone have a side hustle going on?
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Check it out, you might find some new flying friends…
Good on you for getting that drone registered and the TRUST Certificate.
Now, unless you had other drones that were little more than a kid's house toy, those inexpensive non-GPS drones force the pilot to learn to fly. Because in even a light breeze, just to hover, you had to fly the drone, so please do not dismiss then so lightly…
I am enrolled in three colleges courses right now looking for my Small Unmanned Aircraft Systems Technician Certificate and there are several DJI owners (besides me, I have a Mini 2…) in the class and they cannot fly the course's required flight patterns: figure 8 with the drone always facing in the same direction nor with the drone facing forward, a square pattern horizontally and vertically, and many more. These patterns and others show the pilots proficiency. These other students never learned to fly without GPS and if their GPS failed, they would never get their drone home…
Link to the FAADroneZone, keep this link handy so you can request flight authorizations in controlled airspace.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Indiana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Happy Droning…
Happy Droning…
HOME POINT and RTH ELEVATION…Sooooooo important. Great resources and advice LoudThunder. ✅
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
Birddog495
