Help. Max distance reached
sparky1111
I'm only 150ft out and not in beginner mode.
The only change was an update to local restrictions in the update.
My altitude is only 55ft and no airports nearby.
I've rebooted all equipment but nothing.
It's as if this is normal.
I'm in England postcode PE24.
Help!!!
Reactions: BRW
If you have recently upgraded your firmware, you need to log your DJI GO app into your DJI account to lift the flight restrictions. You only have to do this once...
I'm having the same issue. My mavic just started having this same issue today and it was working fine two days ago. I hav not done any updates in the last week.
Can someone give me a step by step process on how to eliminate the restrictions?
Bloody hell this altitude hack works.
I'm on latest firmware on all devices on ipad mini 4 and went above the limit. Won't say how much over but it works.
About time!
I'm a sensible flyer with a lot of experience now and never put people at risk and never will.
How do I log my DJI GO app into my DJI Account?
If you're currently logged into DJI GO, you can log out like this:
Once logged out, DJI GO will prompt you to log in like this:
If logging out and back in does not lift the restrictions, then uninstall and reinstall DJI GO.
I had the same problem after doing the update on July 1. Wasn't able to fly more than 150 feet. Found that if you remove the DJI 4 go app and reinstall it that should work.
Strangely the restrictions only applied to the Ipad and not my Samsung S5.
Reinstalling Dji on ipad fixed it.
Reactions: Ladderco604
Dean1980
