HELP
Hello from the Crossroads of America MrBigIdwa.
Nice to meet you. 🤝
You might try taking a picture of the screen and have Google translate the text. 🤔
You might get enough information to navigate the menus and find the language settings.
Good luck and welcome to the Forum. :cool:
Greetings from Birmingham, Alabama
See it this video helps
I found this short video.
Nice to meet you. 🤝
Brilliant. I will try that. Thank you very much. And nice to meet you also. God bless.
Received new Mavic 4 Pro
You did not include a location so we do not know where in the world "Waldo" is located, only that you do not read Chinese and prefer English, so I will assume that you live at "Point Nemo" .
The reason your location is important is that everywhere in the world (except Point Nemo…) there are rules and laws governing the owning and flying of a drone and if we knew where "Waldo" is, we could advise you…
Hope the video previously mentioned helped resolve the Language issue…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
sofastmoto
