mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
How to fly a drone legally and safely in Canada
tc.canada.ca
You wrote, "
I'm ready - prepared for that first flight..."
Sorry to say,
No You Are Not, no matter what you have read, not matter what you have watched, that moment that your new Drone rises up into the air; your view of the world will change forever!!!
Here is some more for you to read before that package arrives and while your battery is charging, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
